Help! Trying to put my Ultra Classic back together...
I've got a 1990 Ultra Classic that I'm in the process of getting back on the road. My clutch crapped out on me, and I got sucked into the "while I'm in there, I might as well..." rabbit hole. So I took it all apart and got the final drive belt replaced, reinstalled the inner primary, replaced the clutch fibers and steels, and got the primary chain and tensioner loosely installed, but I'm having trouble finding the procedure for torqueing down the compensator sprocket for my model year. Can anyone provide the correct procedure?
From there, just clean the threads, couple drops of red locktite and (going from memory but I think this is right) 150 ft lbs on the comp nut.
Ziggie (04-28-2017)
There's no tension spring but there is a spacer behind it. Go here and enter the year and model for exploded views.
http://partsfinder.onlinemicrofiche.com/ronnies/showmodel.asp?
http://partsfinder.onlinemicrofiche....showmodel.asp?
Appreciate it, but only models it pulled up for 1990 are sportys. I'll make my way over to my local stealership and have them pull up the exploded view. Someone's been into this primary before me, and I'm fairly certain there was no spacer when I took it all apart.
Ziggie (and Others),
This link will give exploded views of everything for your model...
http://www.dodgecityharleydavidson.c...-81015-H030065
