Brake fluid capacity
About an egg-cup each! Make that a couple each, allowing for flushing out the old fluid until the clean stuff flows. I have two bikes that use DOT4 fluid, so blew out on a fresh 1 litre bottle so I could service them both - I still have more than half of it left! A litre is pretty close to a US quart, so for your brakes you can probably get by with around half a pint.
Received 5,373 Likes
All in know Graham is the po mixed dot 5 and 3 together and it crystalized causing the brake failure in the first place. I bet anything there's dot 3 in rear brakes. I wanted to make sure nothing mixes in rear and the front is cleaned out of any contamination from the damage that mixing the 2 brake fluid had caused.
I'd just use the DOT fluid to flush. But, if you must use alcohol to dry everything out, then use rubbing (isopropyl) alcohol. Don't use that "70%" garbage as the other 30% is water. You don't want water in your braking systems. Isopropyl 99% is much purer.
Good luck with your flushing.
