Fuse box?
i thought I read the fuse were behind the headlight?
thanks for the help
Im really new to the FL world. I did rebuild the carb and got the old bike running really well, and now this happened. I don't want to start pulling headlights or whatever until I know how to proceed, and am getting different messages on exactly where the fuse would be, and if it's the fuse at all? Never had a radio on a bike before.
Thanks for any help
It is quite likely the fuse for the radio is inside the fairing. Others in here can hopefully guide you in gaining access to it. This is an opportunity for you to get yourself the correct factory service manual, which will empower you with such info, at your finger tips! They are available at your local dealer. You will find it a valuable source of service and diagnosis info the longer you own your bike.
We need a fellow FLHT owner to answer those queries. Behind the headlights IMHO means inside the fairing, in other words the same thing. Getting at the radio requires partly dismantling the fairing. Check behind your side cover to see if the fuses are identified. You can see what that may involve by checking an on-line parts website.
jallen28145
08-17-2013 12:53 AM
