New cv carb setup jetting
Old 06-18-2017, 08:04 PM
timsmcm's Avatar
timsmcm
timsmcm is offline
Default New cv carb setup jetting
Here are some picts of the spark plugs. Does it look to you folks that I might have a front cylinder intake leak? Two picts are of the front plug (different angles) , 1 picts of the back plug. Back plug looks a little rich, front looks a little lean. What do you think?
Attached Thumbnails New cv carb setup jetting-resized952017061895194349.jpg   New cv carb setup jetting-resized952017061895194500.jpg   New cv carb setup jetting-resized952017061895194402.jpg
Old 06-18-2017, 08:13 PM
0maha's Avatar
0maha
0maha is offline
Received 4,667 Likes on 1,660 Posts
I'm on my phone and can't see the pics that well, but that rear plug looks more like oil fouling to me.
You getting any exhaust smoke?
Edit. Never mind. I got a better look at it. What jets are you running?
Old 06-18-2017, 08:44 PM
timsmcm's Avatar
timsmcm
timsmcm is offline
46 idle jet 185 main. Does that front plug look lean to you?
Old 06-18-2017, 09:13 PM
0maha's Avatar
0maha
0maha is offline
Maybe a little, but it's hard to see. In any case, it doesn't look terrible, even if it is.
The rear, on the other hand really does look bad. Either crazy rich or burnt on oil.
Have you compression tested the motor?
How many turns on the idle jet screw? Stock needle?
Old 06-19-2017, 12:51 AM
timsmcm's Avatar
timsmcm
timsmcm is offline
Everything was fine until I swapped from butterfly to cv carb. I purchased an older intake and I think it is too short and I have a leak in the front cylinder. The back plug is not oil fouled it is rich. It looks like I might need to go a size smaller idle jet and main jet, and get the front leak fixed.
Old 06-19-2017, 08:24 AM
89FL's Avatar
89FL
89FL is offline
Are you using the stock air cleaner? I read somewhere that the front cylinder normally runs leaner than the rear one, and you jet the carb off the condition of the front plug, although your rear plug does look too rich. How does the bike run?
Old 06-19-2017, 12:22 PM
timsmcm's Avatar
timsmcm
timsmcm is offline
Like I said in an earlier post, the bike was running great before the change over. I just did a compression test. Back cylinder 121, front cylinder 119. That was with an auto zone tester, they are notorious for not being accurate and reading low so I am happy with those readings.
Old 06-19-2017, 12:31 PM
0maha's Avatar
0maha
0maha is offline
Yeah, the absolute number is less important than the fact that they are essentially the same.
I think you are on the right track thinking intake leak. Need to get that sorted before you consider jetting.
Old 06-19-2017, 12:46 PM
timsmcm's Avatar
timsmcm
timsmcm is offline
Yes I am trying to find the part number of the larger intake seals harley makes. My intake looks a little short and I have read that harley made larger seals for that particular problem . Anyone have some suggestions?
Old 06-19-2017, 12:56 PM
Jackie Paper's Avatar
Jackie Paper
Jackie Paper is offline
Received 4,529 Likes on 3,782 Posts
The only time I have see a plug as clean as your front if it truly has the miles on it as the back one is either your rocker or pushrod on the intake valve is completely broken and the valve is not opening or you have not turned on the water injection on the back one. That is what a Z28 looked like that I overhauled a long while back....Go easy on the water, it's rough on starter housings...
Both my sets have 10K but my bike is FI I truly think you are maybe a tad lean but the back cylinder has a mechanical issue like a bad valve seal probably if compression matches front. Be sure to check with a good battery with the carb held Wide Open with the throttle.
Quick Reply: New cv carb setup jetting
