Radio fuse?
Old 06-21-2017, 08:29 AM
jqb12's Avatar
jqb12
jqb12 is offline
Default Radio fuse?
Any idea which one of these may be for the radio? I was hoping to find a glass inline fuse, but no luck.
thanks Looking behind the headlight.
Old 06-21-2017, 10:36 AM
yellowstone kelly's Avatar
yellowstone kelly
yellowstone kelly is offline
Pull each of the four fuses shown in your picture (15 amp, 2 amp, 10 amp, and 5 amp), one at a time, then look at them from the side to see if any of them are blown. The S-shaped fuse filament shown in this example may be more like a U-shape in your fuses, depending on the fuse manufacturer. But when they blow, you can usually see it pretty easily.
Make sure you put each good fuse back in the same place it came out of.
Old 06-21-2017, 03:18 PM
jqb12's Avatar
jqb12
jqb12 is offline
Are these fuses, and if so how are they removed to be checked!
Old 06-21-2017, 03:34 PM
rizzo's Avatar
rizzo
rizzo is offline
Received 4,619 Likes on 2,094 Posts
Those are relays. Do you have an aftermarket head unit, if so it may well be on the unit. Having the manual will make your life a lot easier.
Old 06-21-2017, 04:22 PM
jqb12's Avatar
jqb12
jqb12 is offline
Thanks
Old 06-21-2017, 04:26 PM
jqb12's Avatar
jqb12
jqb12 is offline
The 95 FLHT didn't come with a radio. There is a Sony player in there now that won't power on. Checked all fuses in the pic but didn't know what those were in the black holders. Guessing I'll have to pull the fairing to sort it out
Old 06-21-2017, 05:06 PM
rizzo's Avatar
rizzo
rizzo is offline
On a Sony look on the back of the unit where the harness plugs in and there should be a fuse on the back of the radio chassis. The four nuts on the side of the headlights are a bear to reach when taking off the outer shell. I got a set of swivel head ratcheting wrenches and that's one job where the paid for themselves.
Old 06-21-2017, 06:52 PM
jqb12's Avatar
jqb12
jqb12 is offline
OK cool. Thanks
Old 06-21-2017, 10:30 PM
jqb12's Avatar
jqb12
jqb12 is offline
any idea where the fuse might be?
Is that it next to the green wire, below those 2 large harnesses?
Old 06-22-2017, 06:34 AM
rizzo's Avatar
rizzo
rizzo is offline
It's hard to tell -there's a lot going on there. Below the gray wire buried I see red - that might be it. You may need to remove the nut on the back of the unit, unplug the harness and push it forward to see more. The entire unit should slide out of the dash
Quick Reply: Radio fuse?
