need alittle help with a tach and winshield
Received 4,317 Likes
Yea, good luck finding one... They don't make it any more... I have 2 and neither work. They have an adjustable potentiometer in them for calibrating that tend to lose connection.... If any one knows who can fix them, I'm listening...... That's why I purchased my Dakota digital Speedo with tach...
There's lots of them aftermarket from $30 up:
https://smile.amazon.com/s/?url=sear...rley+mini+tach
98, if you know what value the resistor is supposed to be set at, it wouldn't be too hard to hard wire one in place of the pot.
The part number is P/N107612
I have one on my 1997 Softail with a stock Harley windshield.
The bracket is bent at about 30 degrees and is mounted to the two back handle bar screws. I needed to get longer screws and put a spacer between the back of the bracket and the handle bar clamp to space the bracket up to clear the top of the clamp.
