while I'm in here
Progressive cartridges up front and HD Premium ride hand adjustable in rear. Very satisfied with the ride and handling. As already stated the progressives do away with the need to change fork oil and are a great improvement over stock. The reason I went with HD on rear was that they are easy to adjustment as I go from Solo to 2 UP to 2 Up loaded quite often. Also another huge improvement over the stock air ride. I am sure there are better setups out there but for the money and the easy of adjustments and maintenance, I think it's a pretty good combination.
Originally Posted by flhchaz
Thanks for all of the replies. I think I'm going to get the Progressive cartridges for now and use the stock air shocks in the back for now.
For the rear you may want to look at newer lowering or street glide shocks. I bought a practically new set from a forum member way cheaper than new aftermarket. They have the ability to run up to 50psi, so you have a great range of adjustment. They bolt right on to our frames, lower the *** about an inch, and improve the rear stability. I haven't noticed that I drag harder or more than before.
I seen a set on Pitt CL for 75$, of course right after I bought mine. But why pay 400+ when you can get a good set of showa air rides for under 100? I personally like the air ride, but that's just me. After riding the softail it's like riding an old Buick, you know the one: the gunships from the late 70s.
deuce_streetbob
06-19-2013 09:35 PM
