84 Softail oily around crankcase breather filter?
Hey Guys,
After years of riding twinkies I've got my first evo, an 84 fxst. There really doesn't seem to be any oil leaks apart from the area around what I think is an aftermarket crank case breather filter? I can't tell yet if it's the breather misting and spraying oil around or the transmission cover is a bit leaky
Do I really need this filter?
Thanks,
MAtt.
Thanks,
MAtt.
Received 4,317 Likes
Hey Guys,
Thanks,
MAtt.
Thanks,
MAtt.
Plenty of people will tell you don't need it...I will not run without one...if there is a hole, some kind of insect/critter will crawl in it.
If you have mist coming out the breather, something is tired in your motor...top-end or breather bore.
Since I haven't had a problem running an open breather hose in the last 7 years, might would be more accurate IMO.
When something clogs up that breather, and your motor is leaking oil from every gasket on it... you will rethink your decision. To me it is the same as running with no air filter on the carb...lots of people do it, but it will lead to problems down the line.
I grant you that the possibility exists that something might happen but I disagree that it is a forgone conclusion that it will.
Everytime I go for a ride I might wreck but that is far from actually wrecking.
Oh it's misting oil !!! Doubt it's tranny,I've said this many times before,probably running oil level at full when it would better off half quart low,more room to breathe. That filter looks too short and low not to be a problem. Mine runs to the air box (where everyone else hates it) ,and it stays spotless...
This is quite possible. I don't have a great history on this bike. Previous owner has had it for 20 years and tells me the engine is bone stock as far as he knows. It's got about 60k miles on it.
