Mikuni HSR 42 Tuning.
I posted this over in the Carb section as well. Hopefully Y'all can help me out with this one.
I have a 1984 Electra Glide with a 1996 Road King engine in it. The guy I purchased the engine from says it is bone stock. The bike has a Crane HI-4N ignition system. I keep having an issue the bike will start and idle good and has excellent power but when I am cruising I have noticed that the bike will run good and out of no where is will stumble and pick back up running right where it was. This is been an on going problem with this engine and the original engine with an EV27 Cam. I have noticed that if I keep the engine revved up some it doesn't seem to happen as much. trying to figure out which way to go with jetting and such. It currently has a 167.5 main jet and a 27.5 pilot and the needle is set one slot down from the middle slot. I had a 25 pilot jet in it and when I went to the 27.5 it seemed to get a little better but is still doing it. I don't want to go too crazy in jet sizes. Has anyone had these kind of issues and what was your fix?
Any help is much appreciated.
You don't say what you're running for pipes and air cleaner, but that setup sounds a bit on the rich side for a stock Evo. What kind of fuel economy are you getting? What air cleaner? What exhaust? I'd also check to be sure you're not trying to compensate for a manifold leak.
Are you sure the stumble is carburetor related and not an ignition issue?
This! They set me up with the Mikuni "mileage kit", and my Evo Softail has never been happier.
