Replacing lifters without replacing oem solid pushrods?? Don't want to open Rocker
Without sounding repetitive , I asked:
In what order should the following work be done: cam, cam bearings, quickie pushrods, lifter block gaskets, and lifters.
Yes, I am getting a service manual!!
I understand that I have to cut the original pushrods..so, do that first, and then what?
Also it looks like I will need adjustable pushrod tubes, correct?
Thanks boys!
Thanks boys!
Received 4,317 Likes
Thanks boys!
Thanks boys!
2) Take out pushrod covers
3) Remove lifter blocks and lifters
4) Remove ignition pick up (mark it's position for reference when installing later)
5) Remove cup on end of cam
6) Remove cam chest (cam will probably come out with it)
7) Remove cam bearing
Install in reverse order
Your FSM will give you a better more detailed list.
Stock pushrod covers will work fine with adjustable pushrods
jasonbum (09-08-2017)
