Replacing lifters without replacing oem solid pushrods?? Don't want to open Rocker
#41
It is necessary to drop the front motor mount on FXR models to remove the rear rocker box.
#42
Thanks guys for all your help with this. Everything is installed and she runs!
Andrews Ev13, Andrews EZ adjustable pushrods, Johnson Hilyft lifters, torrington bearing, New oem breather.
Next I have to clean/rebuild the carb. Just ordered 27094-88 needle, and plan to change jets probably to 45 slow, and probably 170-180 main. Some say to leave the main alone?
#45
