Throttle and idle question(s)...
My '95 had a CV on it when I got it. I didn't like the way it ran so I had it rebuilt and tuned by an expert.
Still wasn't happy with the way it ran so I pulled it off and put on an S&S E and it was like night and day.
Ever since that day I've been a believer in the E carb and I've never looked back.
I wish you luck in finding a fix for your carb but the best way I know how to fix a CV is to replace it with an E.
There's no reason a CV can't run perfectly well!!!
Finally got tired of adjusting in perpetuality the throttle and idle cables. Every time I would, the adjustment would last maybe 50 miles and then the poor bike would be back to idling strangely. Part of the problem I am absolutely positive about is, the idle cable - no matter how it's adjusted, at the carb it has about a half an inch of loose and sloppy play to it. It isn't doing anything that I can see but is somehow screwing things up even as loose as it is.
So, I ordered some new cables (Thanks Ronnie's H-D for having 20 year old parts for my bike!!).
If it helps, you can set your idle RPM's by ear. Here's a vid of mine at idle. This is right around 1000RPM.
Also, here is some good troubleshooting information from CV Performance.
Received 4,317 Likes
Remember back when our SBC wouldn't run right and we couldn't figure out why? We just could'nt get that Rottenchester tuned in.... So what did we do?
PUT A HOLLEY ON IT.......
So do the math, Holley/SBC, S&S/EVO........
WP
Now, now.
Did the new cables take care of the half inch slop problem?
https://youtu.be/DwZxBJKqoNQ
Yes, that's what I was letting that rizzo turd realize, I can tune it to idle quite well by ear, and if I idle it (by ear or by tach/rpm on my timing light) at what you have in the video, it's where it coughs really badly if I barely tough the throttle, but when I idle it around 700 or 750, it'll be okay.
Yes, been over to that site checking things already, heh.
Maybe one day if I can get out of this debt, I'll try a s&s.
