Dremeler through plug. Worried
like the good DR said crank the engine over for a minuet deal with the mess, I would add putting a small thin round magnet in the hole and 39 seconds later pull it out and continue to flush if that's what lets you sleep at night then DO it
PS don't be modding the other screws just fix what happed and move along get a new screen
I had heard that it was 37 seconds, could 2 seconds make that big of a difference?
Most of us in the Evo section use non-synthetic (AKA "dino") 20W50. I would guess that most use the genuine H.D. non-synthetic 20W50, then next comes about any other non-synthetic 20W50 and last is full synthetic 20W50.
Uh, time to get a shop manual. FACTORY shop manual. It will save you a lot of pain in the future. BUT FEEL FREE TO ASK US ANYTHING.
You'll be fine. I had to drill mine and use a bolt extractor a few months ago. I don't think it had ever been removed. I had the motion pro tool, and it still wouldn't come out. Got shavings down in there but got it all out with a magnet. I put one of these in its place:
http://www.ebay.com/itm/Colony-8703-...JY-aw0&vxp=mtr
I've also read about people cutting the slot deeper. You just went a little too far sounds like. No big deal. It's a bad design.
Received 4,317 Likes
What bike do you have again?
Shifter
I've ridden the bike around 200 miles and I've noticed sometimes when downshifting like at a light the shifter will move but not catch a gear. So I gotta rev a little and it'll down shift. I've had better luck down shifting while moving and coming to a stop but sometimes I like to coast in neutral to the light or the stop.
1997 Fatboy
1997 Fatboy
1997 Fatboy
1997 Fatboy
IE the locknuts backed off the rod connector ends.
Next with the bike off the ground put it in 3rd gear and with you hand see if the shift linkage moves the same distance forward and back.
Once you have done that then let us know what you found.
