I really lost myself this weekend
Old 10-17-2017, 07:44 PM
1997bagger's Avatar
1997bagger
1997bagger is offline
Received 1,625 Likes on 842 Posts
Your going to need a garbage can somewhere in this build if your married.
Before you get too big I was checking on building a 89" upgraded to Axtell cylinder 106" the guru that does my head work said it takes way too much work for a stock Harley Evo head to flow the air needed. He said it is better and more economical to buy a set of aftermarket heads after the labor involved to to make the Evo's work. Not going to doubt this guys wisdom, I did what anyone would do is bought a set of big flowing heads bolted to a engine block.
Make sure you have the whole engine package figured out, this stuff is touchy and expensive
Old 10-17-2017, 09:01 PM
Mattbastard's Avatar
Mattbastard
Mattbastard is offline
Received 1,408 Likes on 864 Posts
Thanks for all the feedback everyone.
Ya know, I'm well aware that I can buy a V111 (for $5800, because I have to go to Phoenix to pick it up, and pay the tax), but I really like to build something instead for ~$4000. Part of this experience for me isn't just the outcome of riding a ripping good motorcycle, it's the build. All the hours of elbow grease and skinned knuckles that went into your creation, that's more of the satisfaction for me than actually rolling down the road on it.
Maybe I'm weird, I dunno, but I get more satisfaction out of resurrecting a dead motorcycle than actually riding it. Back a few years ago I got a free CB200T with a stuck valve that I brought back to life that hadn't run since the Reagan administration. That was very rewarding, then I sold it for $50.
The following 6 users liked this post by Mattbastard:
2017M8 (02-17-2019), bentparts (07-19-2018), lh4x4 (11-12-2017), Lil'Mugsy (12-22-2020), mike131 (12-21-2020), NVjeff (01-01-2021) and 1 others liked this post. (Show less...)
Old 10-17-2017, 09:05 PM
0maha's Avatar
0maha
0maha is offline
Received 4,667 Likes on 1,660 Posts
Not weird.
The following 3 users liked this post by 0maha:
2017M8 (02-17-2019), TwiZted Biker (10-17-2017), Uncle G. (10-18-2017)
Old 10-17-2017, 09:21 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,763 Likes on 17,437 Posts
Originally Posted by 0maha
Not weird.
I know there's something supremely satisfying about firing that mother up the first time after a major R&R on a tired beater or basket case.
Old 10-19-2017, 03:16 PM
IBDAGRIZ's Avatar
IBDAGRIZ
IBDAGRIZ is offline
I build my own motors too. Built my own shovel scoots as far as frame swaps and motor work too.
Way more fun in it.
Griz
Old 10-21-2017, 07:24 PM
Mattbastard
I was thinking of starting a new thread for the actual build but **** it, I'll just keep updating this one for those of you who bookmarked/subscribed to this thread.
Today was another blast in the garage, so to speak:
Harbor Freight sand blast cabinet and 25 lbs of black aluminum stuff to blast with. I screwed it to the wall.
Fixed a certain swingarm weakness. I'm NOT changing all the damn bearings in the wheel to 1" just for a swingarm. This was like $2 in steel:
Made a special tool for drawing the crank back into the case:
That's a 7/8" X 14 nut, screws right onto the left side shaft on the crank. I also bought a bunch of huge washers and one 1.5" nut for spacing. I'll set everything upright, then rest the nut down on the case and a few washers until I can only get about two turns on this special tool, then when it bottoms out take it off and add washers until it's all the way pulled in. Then check clearance, change shim if needed. I've got a 20 ton press for getting it back out.
Also painted the footrest mounts. They were in **** shape. I blasted/sanded them down, then hit them with some jet black urethane paint with a dash of hardener mixed in:
That orange peel is really gonna make them look OG.
Tomorrow I'll get that swingarm all cleaned up for a layer of paint too.
Old 10-21-2017, 09:09 PM
0maha's Avatar
0maha
0maha is offline
Nice. Like your idea for pressing the bearing on the crank.
Old 10-23-2017, 06:16 AM
Nikolaiownz's Avatar
Nikolaiownz
Nikolaiownz is offline
nice build... subbed.. i own a 96 electra glide (Y)
Old 10-24-2017, 10:19 PM
Mattbastard
Keepin' it real on a weeknight, pressing in the new swingarm bearings on the newly painted swingarm, and checking spacing. I also sandblasted the inner primary but that's nothing special to see.
Old 10-25-2017, 07:49 AM
0maha's Avatar
0maha
0maha is offline
Beautiful!
Quick Reply: I really lost myself this weekend
