I really lost myself this weekend
#361
#362
Not calling you a liar, but genuinely curious since that might have been a better source for these things.
#363
Believe it or not, the laser is just to let you know the general vicinity of the temp reading. The IR tool measures like a saw'd off shotgun (the further away you are from the heat source, the larger area is being measured). If you're an inch away from the heat source then it's pretty accurate. If you're a foot away, the radius of measurement is 3" off the laser dot. 3 feet away and you're reading about a foot diameter worth of surface around the laser dot, or basically the whole top end of the motor. These thermocouples will get me exactly the data I want without guesswork.
And yes, 300F and up is normal. Over 375 is where I'll start worrying. 450 is the danger zone.
#364
The problem with the IR gun is it's measuring an average temp around a certain radius away from the little laser pointer.
Mattbastard (02-11-2019)
#365
ok, i might have misstated slightly. the head temp. gauge was an official HD accessory that was available in 85. it has 4 gauges, clock, oil pressure, volts and head temp. the caddy also held a **** type radio that you had to supply yourself. i believe it was called a "california radio caddy" or it was made by california caddy co...or something like that. the 85 came empty inside the fairing like the older shovelhead baggers. the original eyelet was copper. the one from the hardware store is copper as well and exactly the same size.
#366
https://www.hdforums.com/forum/evo-c...-this-fit.html post #12 and #50 is what my set up is. my kit came with a head temp gauge that says harley-davidson on it....as did all the other gauges.
#368
#369
i never checked the temp with an IR reader but the temp on the gauge usually runs about 350 or slightly lower. like i said i never checked it so i don't know how how accurate the gauge is. i have run r n12yc champions for years. over 100,000 on it. it uses some oil, doesn't leak all smoke (6-800 per quart) but it runs so good i'm afraid to do anything to it. i think the valve guides and valve stem seals are shot.
#370
Nope. Not only is that electrical connector not rated for the temperature range max of a cylinder head, it's too large for the spark plug. The thermocouple based ones are stamped steel to fit perfectly under a 14mm spark plug.
Thanks for the pointer, but I'm way too OCD to be half-assing it considering this is the 3rd time I've put the damn motor together.
