I really lost myself this weekend
Old 02-11-2019, 05:12 PM
Schex's Avatar
Schex
Schex is offline
Received 6,816 Likes on 1,760 Posts
Got me thinking Matt, I still have a Mychron gauge from my kart racing days, we used to monitor and data log head temp and exhaust gas temp, and a few other things, used to shoot for 375-420 head temp running methanol, to high of a gear ratio or being too tight on handling and temps would shoot up.
I’m guessing 350- 380 should be good on the HD,
I’ll be doing some carb maintenance on the 111 soon and going to recheck afr and probably check both cyl head temps with dual readout Mychron just because. Interested to see the relation between the AFR and HT’s.
Mychron gauge and head and egt sensors.
Mattbastard (02-11-2019)
  #372
Old 02-11-2019, 05:31 PM
TSheff's Avatar
TSheff
TSheff is offline
Received 3,344 Likes on 1,550 Posts
Originally Posted by Schex
What's the temp in the Blue & Silver can? Hope all is well with you and the family. Wolf on the road again?
  #373
Old 02-11-2019, 05:57 PM
Schex's Avatar
Schex
Schex is offline
The temp is just right, We doing OK, Wolf's not back in the wind yet, he did ride a trike I had here a while back, he's doing OK though, hope everythings well on your end.
  #374
Old 02-11-2019, 06:45 PM
Mattbastard's Avatar
Mattbastard
Mattbastard is offline
Received 1,408 Likes on 864 Posts
They came in today!!! I might buy some 12mm ones just to have them for future projects. They're great quality.
Stainless steel, my bad:
Thickness check:
Calibration check. Good enough for the girls I go out with:
Installation:
The plugs bent them a little but no biggie.
  #375
Old 02-11-2019, 06:49 PM
Mattbastard
I just realized, my bike is gonna look like some crazy science experiment with all the wires looped all over it going down the road.
  #376
Old 02-11-2019, 07:39 PM
TSheff's Avatar
TSheff
TSheff is offline
Thanks for the info, tell Wolf I was thinking about him. Life good here, just getting older, Waiting for the next EVO to come out from hiding.
Now back to the EVO Head temp gentlemen. Carry On.
  #377
Old 02-12-2019, 07:14 AM
bagga's Avatar
bagga
bagga is offline
go out there and run it about 75 for half an hour and let us know what the head temp is. my guess is right around 350 for the rear head.
  #378
Old 02-12-2019, 07:32 AM
LQQK_OUT's Avatar
LQQK_OUT
LQQK_OUT is offline
Received 1,563 Likes on 1,082 Posts
If one wanted to read head temperature, couldn't I just use an infrared laser thermometer? It doesn't have logging capability, but at least I don't have two unsightly wires on my engine. Plus I now have the ability to measure other points on my motorcycle, like exhaust, electrical circuits, etc.
https://www.harborfreight.com/121-in...ter-63985.html
  #379
Old 02-12-2019, 07:44 AM
Steve Sportster's Avatar
Steve Sportster
Steve Sportster is offline
Received 2,256 Likes on 1,096 Posts
Probably a bit too technical for some, but infrared thermometers are often off due to the IR emissivity of the surface being measured. Highly reflective metals have very poor emissivity and therefore give inaccurate readings. Oxidized metals typically yield more accurate results. I have been dealing with the IR emissivity of metals for over 40 years. Fluke makes good adjustable meters that are superior to low end devices (much more costly though). How accurate do you want to be? That's the question.
https://www.flukeprocessinstruments....ssivity-metals
  #380
Old 02-12-2019, 09:48 AM
bagga's Avatar
bagga
bagga is offline
the pics i posted earlier where the wires for the eyelet are to the left of the spark plug is not how i route it. i put it directly behind the spark plug and the wire goes up under the fuel tank....it's barely visible that way. the eyelet needs to be bent at a 90 degree angle so it follows the rocker covers to under the tank.
Quick Reply: I really lost myself this weekend
