Wondering if I've been doing this wrong??
Received 4,934 Likes
Thanks for all the input guys. I never thunk to just ask my auto mechanic, who is incredible, for his opinion. He says starve it out ( like I've been doing). The only thing, he did ask what stabilizer I used... and to make sure it specifically says for "ethanol" based fuels. Funny thing is, I was out of the red stuff I alwyas use, but found a can of "Seafoam" in the garage. Besides doing everything except scratch your back, the can says it's an ethanol based fuel stabilizer as well! Sure hope I don't jinx myself with the stuff.
I use stabiliser, not sure if it helps anything but it's cheap insurance. I also run the bike a bit to make sure the stabiliser goes through the whole fuel system. Here's a video of the procedure I go through....
...also has the added benefit of adding a subtle aroma to everything in the shed.
Seafoam is amazing stuff. I've used it as a fuel system cleaner but not as a stabilizer. That's usually reserved for marine (blue) Stabil. I also starve the carb dry and simply attach the battery tender all winter. Maybe over-inflate the tires for it's nap too, then throw the cover on it. Don't over think it. Best thing you can do is completely fill the tank so rust won't form in the neck from condensation.
