Yet another 80" build.
#41
#42
#43
#44
Received 14,138 Likes
#45
Thanks guys, I'll get shopping for a starter and cables.
Hit a bit of a snag upon assembly..... I was turning my rings to spread out the end gaps and noticed one ring wanted to stick in the groove.... I swapped rings around and it appears to be a bad ring and not a piston so monday i will have to make sone phone calls
#46
A few questions on setting up my ultima (dynatek) ignition.
is setting the rev limiter at 6k safe for a stock bottom end?
Also which curve should i run? This is a heavier bike and i spend probably half of my time riding two up.
Ill be using the stock voes and running it on dual fire with a dynatek coil.
#47
#48
#49
Received 4,317 Likes
Start at curve 2 and if you get pinging go to curve 3 if still pinging go to 4.
I always ran mine at curve 2 with no problems.
#50
