'91 FXSTS leaking oil from the carburetor cover?
1991 FXSTS. 12,000 miles. Not started since last summer. Just changed the oil & filter and started it up to let it run for a bit. Everything seemed fine. No leaks anywhere. When I went to look at another bike, I saw a puddle of oil under the bike and went over to investigate. It appeared to be leaking from the carburetor cover so I took it off and removed the air filter. I noticed a small opening on the left side of the housing from which a metal line is attached, and runs down to the bottom of the engine. Sorry, I don't know the correct names of these things but hope you know what this is. If it matters, I had the carburetor rebuilt 2 summers ago. Also, the temperature outside when I started it today was about 50 degrees. Can you tell me what this is??
I can post a pic if that's more helpful.
leaking
Your oil drained out of the oil tank through the check valve in your oil pump into the bottom of the motor. When you started it up the oil blew through the breather and into your air filter and the onto the ground. This can easily be fixed by lapping the check ball seat. It is a common thing and will be easy to fix
lrs52200 (01-16-2018)
Because the bike sat for a while,oil went by the check ball and into the case. They call it sumping. Then you started the bike and the oil was pushed out the crank vent out the breather. Happens to a lot of people,the ball may not be sealing properly.
Now your oil level may be too much and may need to be changed again if the old oil was really dirty.
Received 4,317 Likes
And all was well before the rebuild also,it can't be luck because I just ain't that special.
