S&S 113 oil cooler ?
Does Love Jugs have any cooling effect on your oil?
I suspect the engine will be fine, it's the rider who gets hot! We can bake while sitting on these things in the wrong weather or riding gear. An alternative to an oil cooler is one of the twin cooling fan set-ups, which blow air over each head - Love Jugs, or something similar.
The oil cooler does little when you're in traffic. I'm sure you've experienced that yourself. By the way, there is nothing similar to patented Love Jugs.
I would, when my big cube engine was at 10.8-1 with no oil cooler it was a heat monster even with AFR's rich. When it was pulled down for the valve seat problem it had a heated cylinder, needed bored and new pistons.
Installed the new heads leaving compression at 10.2-1 with a Jagg 10 row, heat has never been noticed in any situation. Never did think a oil cooler was needed until big cubes and they change the rules.
Received 19,683 Likes
Just know how hard a bigger cube engine is to hot start with high compression, it is a starter drive nightmare. Performance is off the charts but would never do it again, starter kickback is a sound I don't want to hear again and will live with a little less performance over breaking a starter drive in the middle of nowhere.
Brad has another thread over in the Engine Mechanical section inquiring about an S&S 631and setting it @ 11:1. The lift @TDC is huge and will require extensive head work to make it work. ntraindavefl Had recommended the 9b and I would have to agree... Sets up good @11:1.
