Stiff clutch, more lubing for tranny push rod?
1985 5-speed. Is there any trick to get more oiling to the long push rod going through transmission? This year model (and some later ones) doesn't have oli slinger on right side, but I doubt that alone would fix extremely stiff clutch.
I think many would appreciate ideas on this particular problem, not on how to lube clutch cable or such basics, or buy more unnecessary replacement parts. Thanks in advance.
It is very unlikely that your stiff clutch is from a lack of oil to the push rod through the transmission. In my experience, it is related to both a clutch plate spring adjusted too tight and the cable itself. Adjust the clutch pack spring per the shop manual to start with. Lubing the cable may or may not help. A new cable with plenty of lube will. After several different cables, I finally found a New Old Stock HD cable at a dealer and after I put that on, it is like butter.
aces&8s (01-26-2018)
Thanks for the quick tips. Push rod is not bent, it's like new. I've had the clutch problem for years, and to my knowledge, so have many others. Replacing cables, diaphragm spring (and its settings), clutch release components and such doesn't help in many cases. One thing not tried/discussed is to get the push rod more slippery. The clutch used to get stiffer periodically, nowadays constantly and expecially when driving long distances as if some component isn't getting lubrication.
Received 4,317 Likes
The 80-85 5 speed clutch release is problematic at best...while similar in design to a 4 speed, it never worked as well. They did away with it in 86. Acquiring the components, and changing it to the ball and ramp design will do more to give you an easy clutch than anything else.
87 they changed it. Making a 86-back use the 87-up "sportster style" ramps is not a small job either, from what I've read.
Really, though, it isn't that bad. Now that I have my clutch adjusted properly and a good clutch cable, it is really pretty easy. And I haven't broken a clutch finger in a long time. Knock on wood.
Make sure that little Teflon sleeve bearing looks good in the lever. And that the lever it self is not so worn that it is rubbing on the side of the case it is capatured in. Aluminum rubbing against aluminum it's rough and under load adds a lot of drag. I had never ever lubricated my cable after over 40k since it's Teflon lined but old age and arthritis had finially made me try lubrication. That seemed to me to make it worst.
