Fxr 113 woods 9b
Have had no problem with a Rivera hooking up even when my engine was on kill before pulling it back. Check your side cover to make sure the weights are not touching the cover stopping full throw, also check to make sure it is adjusted proper. Something's not right here, that clutch is tough.
The 113 is a potent engine, should go thru the tire quickly with those numbers.
Was kinda confused about the gold spring and see why after your pick, I have the Variable Pro clutch, it won't slip unless I sell the other remaining kidney for a Procharger
