Drilling hole for speed sensor in the trans
Again this is just decision on the subject. I was told I can't put newer wheels on an Evo, did that. Was told that I should upgrade my seeingswi to run a newer style caliper on the rear. I plan in it but for now welded a bracket to make my stock one work. You guys that want to laugh and say hold my beer. That's fine but the world has went round without guys like you and guys like me that engineer The tool to get it done are the ones that make progress. I don't have the money for a used case I don't want to tear my trans out. What I do have are tools, and determination and the ability to build something to get the job done. It's just a thought. It's not an action, nothing has been done or will it until I can determine that I've come up with a method that may give a reasonable solution. There is nothing wrong with the front wheel Speedo but in my application it just makes the situation difficult to cut down the Speedo gear and run the cable without having to have a custom one made. I don't want to run one of the rear wheel because it's the same situation it would just be a pain in the ***. To have a Speedo with out the cable is just the best solution. But if it means I have to wait because there isn't a good alternative to treating it all apart then that's what I will do.
GPS speedometer, some cheaper options on Ebay also
https://www.speedhut.com/gauge/GR338...dometer-120mph
Bumpandrun (02-05-2019)
we're not telling you that you can't do it - just that it's going to be a LOT of work for little gain. its ~ 2-3 hours to pull and strip a transmission (i know, i hadda pull mine down last year after bending a shift fork....BTW thanks to Mark@Baker for hooking that one up on a friday night)
that being said - if you're dead set on this, at LEAST pull the exhaust and outer primary and get the gearset out.
