Still can't find Neutral
BTW the screw is the end of the adjust made after the rest is set correctly
Received 4,317 Likes
It takes at least a quart especially when you've pulled off the outer primary.
My book calls for 36 - 42 oz in the primary but it only seems to take that much if I pull off the outer primary.
sB43 (04-20-2018)
Don't go by quantity, fill to the proper LEVEL (see the service manual).
For example, the service manual for my bike calls for 1 quart, but I find I need to use about 40 oz. to bring the level to the proper level (touching the spring disc+1/8").
I loosened the cable before I cracked the nut on the clutch. Adjusted the clutch,tightend the lock bolt ....... then adjusted the cable. IDK if I'm not following you.
Also, after you turn the adjustment screw in until it makes contact, try backing it out less than a half turn. Trial and error, but you'll eventually find the sweet spot where your clutch is happy.
sB43 (04-21-2018)
