Still can't find Neutral
Received 4,317 Likes
What year and model? 97/98 Softail manual Says 97-32 oz, 98-26 oz and for the primary chain adjustment cold-5/8"-7/8", Hot-3/8"-5/8". If you set your chain to 1/2" it's very possible to only have a 1/4" play when hot... cold be too tight which can make it difficult to find neutral....
OP is running a Hayden M6 (completely different critter).
I'm sure there is som break in time on that Hayden. I could always take out a shim. but I'll give it a little time. Took her out today and she shifted smoothly. I'll figure it out. May need to adjust the clutch again. But that's tomorrow. Long ride today. POOPED!
what year and model? 97/98 softail manual says 97-32 oz, 98-26 oz and for the primary chain adjustment cold-5/8"-7/8", hot-3/8"-5/8". If you set your chain to 1/2" it's very possible to only have a 1/4" play when hot... Cold be too tight which can make it difficult to find neutral....
