1998 rear brakes
1998 rear brakes
Ok so I was coming home from work i I hear noises when I hit my rear breaks. So I take a look and it’s time to do breaks but I also noticed that the inside of the rotor ( tire side ) about 1/2” to 3/4” on the outer edge is a bit rough and guess a new one is needed.
So the question is would it be easier to turn the rotor if you can or just put a new one on it
And then is there a certain bolt patter or are they all the same?
Then in my 1998 what break fluid would be in it?
Received 4,317 Likes
To the best of my knowledge all the EVO rear brake rotors are the same.
As for what brake fluid to use your master cylinder cover should tell you what you're supposed to put in it.
My guess is Dot 5.
WindowMan (04-21-2018)
Received 5,384 Likes
My first ever bike with discs was my first Harley, a new 1974 FX1200. The darned brakes were useless, especially in the wet, and only got a bit better when the braking surfaces wore to the point of looking like ploughed fields! So I wouldn't be in too much of a hurry to replace yours.....
WindowMan (04-22-2018)
Scootertrash60 (04-24-2018)
