Oil leaking out of air box
I've got a 1991 FLHS. Recently I have noticed a LOT of oil leaking out of the air box. It mists the fairing that covers the oil tank. When I get home from a ride the fairing covering the oil bag will have a coating of oil on it and oil will drip out of the bottom of the air box and onto the motor. It doesn't leak oil when it is sitting, just when it is running and just from the air box. It seems to be pushing oil out of one of the vent tubes that vent into the air box. Has anyone else had this problem?
Is it a blow by problem? Is one of my cylinder sleeves or piston rings letting oil through or something? It isn't burning an oil and is very strange to me. I can't figure it out.
Could be an excess of blow by gasses indeed. Whats the mileage of the engine? Has anything been done recently to the bike that might have caused this? Done any maintenance or repairs lately?
I had a similar problem (https://www.hdforums.com/forum/evo-c...-cylinder.html) a while back caused by broken compression rings. You might want to do a compression test in order to be able to rule things out.
Your 91 would not be a 'top breather' so that would rule out issues with that. Unless later model heads were installed and plumbed into the air cleaner backing plate. Has the cam chest been open? If the breather is out of time, or is FUBAR, it could possibly cause an issue like this.
Did you change the engine oil recently? How much did you add?
What air cleaner are you running? OEM? Aftermarket?
If it just started doing it...my first guess is just running too much oil in the tank.
Most people remove the vent tube from the air filter, and route it toward the ground to prevent the mess...and they make fancy little filters to keep critters from getting in your vent hose.
They all do it somewhat. Still do. Especially if you run it at the upper rpm range and let it sit for a few days letting oil that got dragged along with the vent gas from the pressure created when the piston was on the intake stroke. (The piston puts pressure in the crankcase and that air needs to go somewhere) Wipe the drool from the old girl's chin and keep getting up. It's been perfectly fine for 27 years and will be for another just like it is.
