Burning Oil looking for thoughts.
Don't think I would be using that shop again. Obviously no one checked clearances....
Anyways to fit those valves into those heads you need to really open up the combustion chamber which would decrease your compression. Curious as to what the compression ratio is with flat top pistons... When I went to over sized valves in my heads which opened my combustion chambers to 94.6 cc, the only piston available was the Axtell 30* angle tops to keep me in the 10-8:1 range... I know that W9B with a 50 IVC loves 10.9-11.1:1. Had to mill my angle tops to get me there.
Good luck with that shop.... will be following this one....
Rpm
Actually beings this is my third set of Pistons since April i took it easy. Did some highway riding being sure to fluctuate the RPMs between 2500 and 3200. Not going above 3200 till after i had put about 100 miles on. Even after that only exceeded 3200 in quick bursts when accelerating to get up to speed.
I've spoke to shop. They claim they did a top notch install checking everything. Said a stud must have pulled out of case. I have reassembled the bike to verify headbolts torque. Guess what, they are torqued to 40 ft lbs.
So question what could be causing me to burn up pistons?
What's my best option at this point?
. Bore Cast Iron Cylinders again to 3-13/16 +.060 which puts me as far as i can go and the cylinder walls will be very thin. Part out motor and buy something used. I'm torn, i do ride this bike daily. The current setup from what I'm told isn't meant for a daily commuter. But damn do i love the power. Would like to hear some opinions?
What does braking in a set barrels and pistons or ring orientation have to do with a valve knocking a piston to jello? Sry to say, but this thing is a mess. 1.5 qrts of oil in 120 miles. Oil pouring from every hole in the engine. Loose head bolts. Missing peaces from pistons...
By this time, if I was riding a bike on a daily basis, I would kill for a reliable stock engine doing its job, put together by yourself, or someone else you can trust.
tar_snake (06-24-2018)
Its a mess
Well to answer questions from #6. Rings were not upside down, valve seals are good. As far as the rest they say they did. They are claiming a stud bolt pulled out so no warranty They cant be for sure until i get bike to them. Unfortunately im 3 hours away with no way to get it there.
Thats kind of where im at as far as throwing a stock motor in it. Trying to sell the heads, carb, cam, rocker boxes and roller rockers. Hoping if i sell all ill have enough to pick up a good used one.
