Electrical Issue???
battery did did test out good for load test. Holds good cranking amps. Idle is 14.1, 2,000 rpm is 14.15.
You realize you sneaked in under the 30 year old EVO section? Don't have a 2016 electrical diagnostic manual. Sounds like your meter is just off. Diodes are bad in the regulator. A bad battery probably did that.
i didnt even realize.. regardless if the only different was to a 3 phase stator and possibly more resistance in stator then every other test your prvuoded is near to accurate even for a later model.. I have seen your diagnose test and followed it and people with my bike have also showed similar number. Charging system would be tested the same way across the board, or near to.
what at do you mean by signature line ?? Your charging system test has been posted on recent post for my year charging system correct?? Thanks for all your input by the way.
Your charging system test is for newer dyna models and possibly other models correct? New to the forum. Really has been helping me out.
Then hit Edit Signature. Add your year bike and all it's letters similar to what I have at bottom for my bike. Then save it
That way when you post, it will be there
Thank all of you for your advise. I bought a multimeter. My old (new) battery took a poop. Wouldn't even charge. So, I got a new battery, and put the multimeter on the bike, and when I revved it, no increase in battery. I put the meter on the stator and revved it. Very low. I have a new stator and rotor. I was anticipating this a couple months ago. So, back to the tear down........ I knew last year when I bought her there were gonna be a couple issues. But I have the parts, just got to get get my hands in her again. Hell, she'll be brand new by the time I get done. Thanks again guys. I'll keep ya posted.
