Need Help Routing Oil Lines for Evolution Engine - 1990 Heritage FLSTC
The large nipple is main feed/drain. You will install a short section of hose, then a T, so that it will branch out to 2 lines, one to the drain, the other to the inlet of the oil pump.
The two forward facing nipples are vent (farthest away in this pic) and return from oil filter (closest).
The pic with the colored arrows has these nipples marked incorrectly
I am confused now, I am not sure what is the correct set-up. Can anyone else confirm?
nordic1 (08-11-2018)
There are only 2 curved nipples on this (1987-1990)tank.
Same oil tank that is on my `89 Softail that I have owned since new, and I have had this oil tank off and on many times.
Thank you Dan89FLSTC. I believe that I have the same exact oil tank as you. My guess is that they made different variations in later years.
Does the T-connector off of the main drain reduce down in size for the feed line to the oil pump?
