Don't know why it' bent, but when swiveled it's slightly out of round. Honestly, don't know if it will hurt anything, not rubbing the tube. Yeah, I hear ya, trying to find just one is gonna be unlikely.
Yes i had to buy a whole ndw set. Which one did u bend, it makes a difference.
How so?
I have seen adj PR all the same length .....But, They are adjustable
These are genuine HD, I will check and see if there is a difference between each other.
Even though they are adjustables, Manufacturers like S&S have 2 lengths. Short for intakes and Long for exhausts.... Which one do you need? Intake or Exhaust?....
I dont need anything
I have 3 genuine HD Adj. pushrods here and "Bentparts" needs one so I am sending it to him
Unless of course, you have a better one to send to him?
These are all the same length.
I have a set of S&S easy install push rods and they are all the same length fully collapsed.
You don't get the different lengths until you adjust it to fit in which ever position you are putting it.
About the only thing bent needs to know is the TPI of the push rod that king is being kind enough to send him.
Knowing that will tell him how many flats to adjust it once he has it in place.
Not sure why which one bent makes a difference but I'd like to hear the reasoning behind that question.
