High idle Electra Glide
Was having a high idle problem, had it diagnosed as intake Manifold seals, replaced the seals and was still getting a high idle just after start up followed by an engine light, it lasted about 20-30 seconds then returned to normal idle rpm, I watched the air idle module and when ever the bike idles up it happens right after the module moves slightly, so I turned on the key let the module do it’s thing as normal when turned on then I waited about 30-40 seconds and the module moved out and the bike was shut off ignition on only, so does this mean I need a new air idle sensor??
