Blinker switch 91 FXR
I got some cheap rear tail lights off fleabay and I'm about to hook them up, they came with two wires. The front blinkers light up but don't blink when you hit the turn signals, maybe it's because the rears are disconnected I don't know. Previous owner ripped out the wiring so I can't even tell where I'm supposed to wire these lights too. I have a service manual on it's way but it hasn't arrived. Any help would be appreciated.
I'm afraid you may be correct. I pulled the side cover and don't see the flasher unit which is why I asked. It could however be the bad lighting I had last night when I popped the cover. Like I said, when you hit the signal the light lights up but doesn't flash. If it's just a flasher that will be an easy fix. My service manual doesn't arrive until next week so I'm relying on the web and apparently EVO's are the new Model T's in 2018. !!
Check this info from the HD Service Info Portal. It has a section on the turn signal canceller (Page 14) and all the wiring diagrams.
https://serviceinfo.harley-davidson....%3D1991+wiring
Depending on the lights you bought your bike used the body for ground originally so the original lights only had 1 wire (turn only, no running light).
The newer bikes and lights use an actual ground wire you have to run and connect under the seat. The connections for the turns are under the seat too.
The right turn is brown
The left turn is violet
