Quick question...
  #61
Old 11-16-2018, 10:26 PM
tar_snake's Avatar
tar_snake
tar_snake is offline
It sure is funky lookin' ain't it? Like I said, it was 4 extra o-rings in the package and I figured they must have been some kind of 'upgraded' o-ring. I sure hope it's those things that *is* the leak.
  #62
Old 11-16-2018, 11:38 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is online now
Received 47,762 Likes on 17,437 Posts
Originally Posted by tar_snake
Here's a really bad drawing of the cross section difference between the two o-rings (I did it with my mouse and it's close enough to get the idea across, heh) and some pictures. The circle in the top picture is the cross section of a regular o-ring. Both of the o-rings are the same inner and outer diameter and same thickness.
It's not so much I don't like the sound, it's just different and I have to get used to it. It's hard to explain why that makes it harder for me to just be able to listen to it and be able to tell when it's idling at 950-1000 rpm's...I can do the same with any carbureted Chevy motor I6 or V8, but ask me to tell what a Ford or Dodge is idling at and I'm usually pretty far off, by something like 300 or 400 rpm's. I just have to spend time around this cam is all and it'll settle in soon enough. I'll hook up my timing light that has a tach in it and that'll get me started on the right track.
The old quad rings LOL!!! Those weren't one HD's better idea's, late shovels and early evos' used those for a bit, still have a bunch in my gasket stash. Dump them and use the regular o-rings you'll be better off.
tar_snake (11-17-2018)
  #63
Old 11-17-2018, 05:45 AM
splattttttt's Avatar
splattttttt
splattttttt is offline
Those wark better in a pneumatic system, than tring to hold back hot oul. Though both are meant to cope with low pressure, I would trust the natural swuish of a round buna style than a quad or x ring. Unless I had a ton of them to try and see which combo worked best.
In this case, I’d just stick to the old tried and trued.
  #64
Old 11-17-2018, 11:23 AM
tar_snake's Avatar
tar_snake
Okay...finally got that checked and it wasn't those o-rings, I guess I'd decided on the normal o-rings. What it looks like happened is, I didn't get the top of the exhaust pushrod tube all the way into its o-ring in the head. It was crooked enough to let a good deal of oil out and half-flattened about a 1/16 of the o-ring. Luckily I had plenty others and replaced it and *triple* checked everything this time (it helped too that it was daylight and I could actually see, lol).
Going to let the lifters bleed down for about an hour just to be catious then take it back out and see how it does. It also looked like the intake pushrod was rubbing slightly on the inside of its pushrod tube. That may have been some of the 'noise' I've been hearing. The adjuster is so low to the top of the lifter guide, that there's no turning, twisting piddling with the tube to get it away from the pushrod, so hopefully it isn't rubbing so badly as to wear a hole in it very quickly. Always something, but hell, we'd be bored to tears if we didn't have something to work on once in a while (I just wish it was the easy-for-me things that would break down so I don't hurt so much after fixing it! muaha).
  #65
Old 11-17-2018, 12:08 PM
98hotrodfatboy's Avatar
98hotrodfatboy
98hotrodfatboy is offline
Received 4,784 Likes on 3,300 Posts
Whenever I install the pushrods tubes up into the head I try to feel for that snap as they go in. I also look up in there with a flashlight just to make sure...
  #66
Old 11-17-2018, 12:55 PM
Uncle G.'s Avatar
Uncle G.
Uncle G. is offline
Received 3,695 Likes on 1,985 Posts
That’s funny. I’ve been using the quad rings in mine for 16 years without a leak, but hey, whatever works for you. You’re sure you didn’t omit one of the little washers that fit under the bottom o-ring?
  #67
Old 11-17-2018, 01:40 PM
splattttttt
I need to plug the trikle charger up. Gotta get the damn seat off! What a PITA
  #68
Old 11-17-2018, 02:16 PM
tar_snake's Avatar
tar_snake
Seems I can't win for losing. Went out to test ride and there it was leaking like a sieve again. The top of the tube. It's seated correctly, I made sure of that and had to lie down on my side while the bike was running to see the oil coming out of it. Only thing I can figure now, is that shaving down the retainer clips made this one somehow not strong enough to keep pressure upward on the tube to press it against the o-ring. It's a Catch-22 though...if I didn't shave it down some, it wouldn't go back on for some unknown reason, there was just too much length on the clip to go back on...yet it came off and I didn't do anything different other than put new o-rings in. Damned if I do, damned if I don't. Friggin' unreal. Went ahead and ordered 4 now retainer clips. Don't know what else I can friggin' do. It just blows my mind that they came off just fine easy as pie, on the same exact tubes, I kept *everything* in its order, which clip went with which tube, which o-ring etc., everything *should* have gone right back without a second thought. I've changed pushrods before, on the '09, and it's a simple job. Washing the damn bike is harder.
  #69
Old 11-17-2018, 02:51 PM
TwiZted Biker
I've had a few I used Hylomar on to get to seal, rare but has happened. Easy to pinch an oring with cold hands or frustrated, done my share of that.
  #70
Old 11-17-2018, 02:56 PM
texashillcountry's Avatar
texashillcountry
texashillcountry is offline
Dirt don't hurt
Received 4,317 Likes on 1,946 Posts
The only time I've had that problem the old top o-ring stayed in the head and I didn't see it before trying to install the new one.
Are you absolutely sure you got the old ones out?
Quick Reply: Quick question...
