My Evo Odyssey.
Just went thru exact same thing 3 days ago. Went to install S&S air cleaner on my Evo. Had been running a different air cleaner on my Super E. Back plate holes didn't line up, just like he first pictured.
Simply loosened the intake flange bolts and "rotated" the whole intake manifold until it lined up. Tightened everything up and it's perfect.
No need to buy anything and rig it.
Whenever I put on heads that have been machined (Decked) I always check the for the fit of the intake runner to the cylinder head ports and then have to hand fit the intake runner to the cylinder head ports. Usually done with a large flat file. Hand tooling... I do this because what's the sense of putting on good heads if the ports and runners don't match properly....
Even a completely stock motor can have the issue he had. The manifold can be rotated slightly, which will change the positon of the carb, which will affect the position of the back plate.
No brainer.
He went and spent money to buy different parts, then had to rig it up to try to make it work.
No brainer.
No brainer.
No brainer.
Not everyone criticized you and not everyone put you in the third person. Some will and some won't... It's all how you want to look at it .. take the good and hopefully it'll all work out for you... Glad you got it worked out... We're you able to support the carb with the 2 breather bolts.... If so who's kit did you use? Got a pick?
When all is said and done. At the end of the day. All that matters is I got what I wanted and I did it my self. As I have mentioned several times. This is my first Evo. I am learning from the dedicated Evo owners here. Thanks.
