Winter Project : ElectraGlide Swingarm, Top End and Bags
#161
#162
#163
#164
#165
Right now, I'm letting my imagination get the better of me. I only checked the alignment of the pinion-cam-breather gears about 17 times before I bolted on the cam chest cover, but I still have this urge to pull it apart and check on more time.
Since I still have the primary cover off, I can put a socket on the compensator nut and turn the motor over. Been doing that at each step. So far, nice and smooth, although I haven't spun up the rear pushrods yet and haven't turned it over with the rockers on. I guess that's the real test.
Here's a question: After I get the front rockers on, would it be worthwhile to use an electric drill on that comp nut to spin the motor until I see engine oil coming up the pushrods?
#166
You have a built-in electric starter motor to do that....
#167
#168
I wouldn't. First step is to get the pushrods set.. then just spin the motor over by hand on the sprocket nut. I was actually able to spin mine fast enough by hand to get oil pressure to read 8 psi on my gauge. One you confirm proper pushrods adjustment by spinning over by hand then use the starter.. That's what it's for.. no plugs and 30 seconds should do it..
#170
Indeed!
I temporarily hooked up the old battery, but it's getting tired and my charger is over at my father in law's shed. Need to go get that and juice that thing up. I can't afford to run down my fancy new battery, since I don't have an external charger for it.
Here's a question: I can't remember if the positive cable ran over or under the starter motor. I ran it over for now. Can't see how it would matter much either way, but would appreciate if someone could tell me how theirs is set up.
