Winter Project : ElectraGlide Swingarm, Top End and Bags
#191
I would think anyone that bolts in a big cam like listed above will take care of the details to make it work the best it can?
Going the size listed above some other serious issues and options need to be performed. (as I am sure you know)
#192
#194
#195
No you have nothing to worry about... That was my W8 build with a lot more compression because I initially had a W9B in there that required 11.1-1 because of the late ivc. My ccp was close to 220. Scott wouldn't do that to you.... I'm sure he has you set up to 200 maybe a tad less... I suggest you measure everything to confirm your build.. starting with Piston deck height, combustion chamber size and the bore, so you can input everything into a calculator for what it should be and the do a ccp test.. Do you have your combustion chamber sizes? He usually markets then in the deck of the heads..
#196
#197
#198
#199
#200
