Shovelhead/Evo Transition - Evolution Bottom Ends
Not in my experience - makes it a real b1tch to ride! Would probably need an ignition system that doesn't need a VOES, so that it can run right. Having owned a new shovel, what made it run in that destinctive way was the poor carb! Mine would 4-stroke on the front cylinder, but 8-stroke on the rear. I could, with a lot of effort, get it to run just right, but it wouldn't stay like that for long.
mike131 (04-21-2020)
All a VOES is gonna do is move the spark timing at idle. Disconnect the switch and your timing will fire closer to TDC, which would in turn lower your idle speed.
Also, not sure you can just "add a VOES" without making sure your ignition is capable of receiving that input to make timing adjustments based on engine vacuum.
Mattbastard (12-02-2018)
Matt, If your referring to me i was only being a little sarcastic.... I have a complete late 90's Screaming eagle ignition module with a Standard Motor Product hall effect pickup in my 77 shovel... I didn't want to add the actual VOES because I don't want an actual vacuum operated switch or my ignition timing to advance at idle.. Just wanted it selectable for when on the road....
If an engine is on the verge of stall at an idle, the idle needs to come up.
The gear-driven pumps, move oil in direct relation to engine rpm.
Scott
Scott
__________________
HILLSIDE MOTORCYCLE & MACHINE, INC.
HARLEY-DAVIDSON SPEED & SERVICE CENTER
5225 SOUTH MAIN ST., MUNNSVILLE, N.Y. 13409
Sales/Support 315-495-6650
www.hillsidecycle.com
Walk-in Retail Showroom
Complete H-D Machine Shop
Case & cylinder boring
Complete Cylinder Head Shop
High-Performance Engine Kits
Crank Rebuilding
Direct Link & PowerVision Tuning
Goodson HD Tooling Manufacturer
Maxton Mile World Record
4500 sq ft. facility
OVER 35 YEARS OF H-D ENGINE BUILDING.
See us on Facebook.
Crank Rebuilding
See us on Facebook.
In fact some of the carb bikes had different cams for the same reasons as the EFI bikes, namely the imposition of different standards of environmental regulations. Our carb Evos had a new cam in 1990 and again in 1993 I believe.
