rebuilt motor weeping base gaskets
have 4000 on my 89 flhtc rebuild and the base gaskets are weeping...i heard somewhere about a "planing plate" for the bottom of the cylinder,that the cylinder warps a lil and needs to be leveled back down? anyone know of this? i think strock makes the honing plate but i cant find it anywhere...any help?
Received 47,785 Likes
If your pulling the jugs a machine shop can true them up, my guy charged 15 bucks per cylinder. He also did the rebore so maybe he gave me a better price, idk for sure.
It it will get the bottoms of the cylinder flat and true with the bore.
I agree with letting the cylinders warm up, they actually grow in length as they heat up and thing seal better. YD
Received 4,317 Likes
My cylinders are off at Hillside at this very moment. Among all the other stuff they are doing, I am having them dress the gasket surfaces. Doing that right means getting the bottom dead perpendicular to the bore and dead flat (of course).
The perpendicularity is the only thing about these honing blocks that would give me concern. If you've got one side of the cylinder a few thou higher than the other, it will still be out of perpendicular after the surface is flat. The difference probably doesn't matter much, but if you're going to true up your cylinders, you may as well do it right.
