Hi I'm looking for help 93 ultra classic forgot key in run position after using kill switch later returned to shut radio off and lights. Now nothing replaced bat yes it is tight and correct all good grounds so far. Changed main relay still nothing please help
If you had power before and after replacing the battery you don't then go back over what you did when replacing the battery and find what you missed.
Dig around in the battery box and find the small wire that you either didn't hook back up...or hooked to the negative instead of the positive...it should go to what you are calling the "main relay"...which is actually the main breaker
