12.74 volts was told the battery was hooked up incorrectly prior to the issue. Battery was replaced by a new one.
Originally Posted by by lv
even with all 3 ignition switch wires disconnected theres still 12.74 voltes the the three 15 amp circuit breakers once the battery is connected
It sounds like something is still hooked up incorrectly, since you have the ignition switch disconnected and the 15-amp circuit breakers are still getting power to them somehow.
You'll have to do as Ripsaw suggested---get a wiring diagram, start at the + terminal of the battery, and verify the wires go to where they should go, and there are no extra wires installed that shouldn't be there.
Yes the is power to the 15 amp breakers with the key on
Ok, follow the trail Is there pwr after the breaker?
Keep going.
I think there are two wires to the Post side of that battery, If so are both hooked up?
