Front cylinder not firing
Hi all
This has possibly been post 100 times over but nothing I have seen elsewhere is of any value. To start with I have a 94 FLSTF and upgraded to Crane Hi 4 module about 30K back and it has started intermittently dropping the front cylinder. Time for plugs and leads so it got them, still the same, tested single fire coil good resistance both sides, so thought it must be module so it just got a new Mid-USA module, still the same. To double check the coil I transferred the firing wire and lead to the bottom coil (rear cylinder) which I had spark from and nothing but now I have spark on the top coil (Front cylinder) but with the rear firing wire from module to it. I have just stopped for a couple of beers coz this is doing my head in, I hope I have not just bought a dud new module or am I wrong with the diagnosis of the coil. I got about 4 ohms on both coils.
Yeah- i got the same problem on my 92 with a hi4(crane). Specs say they want a coil 2-4 ohms- and coils 4 ohms and more can be used- but is not optimal. At this point- like the previous poster stated- id suspect a bad coil. I know it sucks to just replace parts- but sometimes its gotta be done. Maybe you can borrow a good known coil from a buddy to try first?
Thanks Dave I think that a new coil is the next logical step but I am also now suspect of voltage drop with the 12v supply to it, just a theory.
This should have said "thanks all", not often the ol' girl chucks a fault I can't fix but this is a bit different. Will report back when it's firing on 2 again.
https://www.hdforums.com/forum/evo-c...-cylinder.html
Forum member Ihgdale had the same problem and replaced lots of parts, including plugs, plug wires, coil, and the cam sensor with the brown goo, but the thread ended Nov. 5th with no resolution.
Maybe he'll pop back in and let us know if he ever got it fixed.
Received 4,317 Likes
Hi all
If you replace the coil get a good one not the cheapest you can find...JMO
Kingglide549 (01-28-2019)
Also a good quick test for the module is to use a test light to test each control wire to the coil, the light should flash when running or cranking, mine did on the rear pot but just stayed on solid on the front.
