Transmission rebuild
Wish I would have seen this earlier. So I guess this piece of advice is for the next person. The gear c-clip snap rings that go on the shafts have a bevel on the two ends where they basically come to a point. Make sure the point is away from the gear or thrust washer it is next to. Not a huge deal but it sure makes them easier to get off if you have to do it again.
Hey guys, I finally got around to putting everything back together. Got the main drive gear bearings and seal changed. I installed the shift pawl seal, flush with the case, And went to install the pawl shaft, it slides into the hole easily but doesn't seem to go in far enough to put the washer and snap ring on. I'm 100% sure that it is going in all the way, I even tried very lightly tapping it and it just don't seem to go in far enough. Has anyone else had this problem or do I have the wrong part? Thanks guys
Did you replace the shifter shaft bushing in the transmission case?
There have been 2 lengths used, depending on the year.
Earlier transmissions used a shorter bushing, when the later model shift drum/pawl came out, a longer bushing was introduced.
You need to determine which bushing is compatible with the shift pawl you have.
98hotrodfatboy (02-17-2019)
