First Harley = Lots of problems
i don't know about a 92 manual but the wiring diagram was included with the HD factory manual for my 85. it just might be included with the 92 manual.....but then again it might not be. somebody here should know if it is or isn't.
Here's a couple that are on ebay:
Reprinted in a 3 ring binder:
https://www.ebay.com/itm/1991-1992-H...nsU5:rk:3:pf:0
Brand new in wrap:
https://www.ebay.com/itm/1991-1992-Harley-evolution-touring-service-manual-electra-glide-FXR-FLT/372583295074?fits=Year%3A1992%7CMake%3AHarley-Davidson&hash=item56bfb1e862:g:BI0AAOSwrZBcUM-U:rk:4f:0
You could always check Craigslist too, you never know.
Brand new in wrap:
Thanks for all the replies. When you build a simplified harness are you talking about doing it from a kit? I haven't taken the fairing off yet to inspect the wiring in there. hopefully its in better shape then some of the other wiring. I was thinking it maybe a ground wire causing all the lights to not work.
Mattbastard (02-11-2019)
Received 47,784 Likes
The following 2 users liked this post by Uncle Larry:
Kingglide549 (02-09-2019),
tar_snake (02-15-2019)
The following 2 users liked this post by Kingglide549:
tar_snake (02-15-2019),
Uncle Larry (02-09-2019)
The problem is more than the turn signals. The gauge lights and indicator lights also don't work. I'm thinking its one issue causing everything to not work. I'd also rather find the actual problem rather than just run new wires.
If the dealer can get a service manual for $60 I'll go that route. I'll give them a call tomorrow.
Or this link might work
https://serviceinfo.harley-davidson....%3D1991+wiring
I don't know why it doesn't show wiring diagrams. Try this: Enter "1991 Wiring" in the search box on the HD Service Info Portal. Yea I know you have a 1992, but the search results should list "Wiring Diagrams & Electrical Troubleshooting Guide - 1991 & 1992 All Models".
I went ahead and ordered a service manual but they said it would be 1-2 weeks before it arrives and I go back to work the 15th so after that I may not have time to work on it until the end of may.
