Baffles or no baffles
Zach Lopez (04-18-2019)
Received 19,664 Likes
Have you ever tried remove baffles before?
Remove the bolts that pass through the muffler shell securing the baffles. Soak the inside of the walls of the shell with trans fluid or PB Blaster over and over for a period of days. Cut a heavy disc drilled with the three holes in the same config as the discs then screw it on to the end of the baffle. Take a piece of pipe, slide it down the inlet to the disc you cut and start tapping, then lube, then tap then lube. It's going to take a while and its messy. Pounding hard may damage the baffle if you ever want to use them again. Make sure the outlet is braced against something solid but something that will give like plywood or a 2x4. Other surfaces will damage the outlet so the end caps won't slide in again. Repeat for the other side.
If\when the baffle comes out make sure to clean the inside of the muffler shell to remove the excess oil before reassembling. It will sound like crap.
Received 4,317 Likes
