Strange Problem at Highway Speed
#51
Originally Posted by splattttttt
Its s drag pipe
maybe find a way to balance it with gearing
#52
splattttttt (06-17-2019)
#53
#54
#55
Back to the drawing board. Still cutting out. Now it started happening under acceleration from slow speed. Judging by black smoke when choking I am way to rich. Bought a rebuild kit for the carb, new backing plate as the old ones mounting tab was broke at the breather bolt. Also ordered a conversion kit to convert older style rebreather system to new style. Any other suggestions?
#56
Received 4,317 Likes
A healthy 80" will give you something like 160 psi.
If you have something bigger you will get something like 180 or 200ish psi.
If you have to run a 31 and 76 on an 80" motor then you are masking another problem.
Not sure what it is but no 80" needs a 31 or 76 to run correctly.
#57
Originally Posted by texashillcountry
Do a compression test.
#58
Yeah I don't think the jets helped. Gonna pop the original jets back in or even the leaner ones you originally suggested. Give the carb a good cleaning and change out all the gaskets. Will try to borrow gauge to do compression check. Could an intake leak possibly cause it?
WesternNSW (07-12-2019)
