Plug color opinions
Plug color opinions
So i know this is about like starting an oil thread and i apologize..... I just wanted to get your opinion on my plugs. There is about 3k miles on these. Bike runs flawless no hesitation, or coughing, or breaking up of any sort. That being said they look just a tad lean to me but i want a second opinion.
Bike is an 86 heritage. Full s&s carb and air cleaner 295 intermediate and 70 main jet. 2 into 1 pro pipe.
Motor has 10:1 pistons in it with a 561 s&s cam. Running the ultima/dynatek ignition setup.
Plug on the right is front hole. Looks perfect to me. Left is rear. Looks a touch lean maybe??
Received 4,317 Likes
The spot on my thumb is a hammer bullseye. Works like a charm i seem to never miss!
bentparts (05-19-2019)
I will triple check but intake seals were new at the time of rebuild about 3k ago. And before that the plugs always looked just like this with the rear one always being more white than the front.
I guess I can always bump my main jet up one and see what happens.
Bumped my main up to a 72 from a 70. One quick beat run around the block and i like the results. Its hard to see becasue of the stupid camera flash but the rear plug now has a light grey/tan tint to it. And the front is a little darker as well
Still doesn't explain why they are so different though? No symptems of a vacuum leak or anything like that. Bike idles great, never pops or sneezes and pulls hard. Maybe something to do with my intake and or exhaust setup?
First pic is front hole.
Plugs look ok. I always have different looking ones too. Rear does seem lean. If there is no pinging or if you can use a borescope and look at the pistons to be sure there is no damage, I wouldn't worry.
On a side note, I dont reinstall plugs once I pull for inspections. Personal choice but new plug always goes back in. It will always give the most accurate reading then.
