1996 Ultra Classic 5th Gear?
My drive puly stripped I need to replace my 5th gear, Ronnies shows 2 different 5th gears for the 1996 FLHTCU-I Ultra Classic, how do you know which one to order?
I haven't taken it apart yet, I wanted to get the parts here first.
35029-91A FIFTH GEAR, MAINSHAFT $111.99
35029-94 FIFTH GEAR, MAINSHAFT $203.49
The correct part for your transmission should be 35029-94
The -91 part is no longer available
Andrews does not make a main drive gear to replace 35029-94, they only make one to replace 35029-91.
You can use this gear, but you must also use their 5th countershaft gear.
Be careful when removing the gear, don`t drive it out with a hammer, use a puller, the lip on the inside of the case that supports the bearing retaining ring is narrow and easily broken off.
You can make up a puller setup yourself using washers, sockets threaded rod...
