Engine ignition & power
I have a 95 electra glide a year ago it started running bad, no power, when you hit the throttle it would backfire, took it to a shop they said it was the carburetor, so I replaced with a S&S super E, It doesn't cutout anymore, but when I first crank it, it has decent power not like it should, but when get hot, it loses power, feels like something breaking down, when I'm going down the rode at a steady speed it sounds like it coughs or misfires, every once in a while, I have replace plugs & wires, people tell me it the carb not jetted right but I had at 3 Harley shop 1 with dyno, & it still does the same thing, can anyone give me advice on what to do cause I'm chasing a ghost & its frustrating
Hey Man (07-07-2019)
There is a section in the service manual on how to test the ignition pickup in the nose cone, they get hot and can act weird. Is there a brown goo coming out of it? If in doubt for $40 on eBay you can purchase a standard motor products SPA -MC3 Hall effect pickup That's a direct replacement for your Deutsch connections. Just scribe where the old pickup is timed and install the new one. I've used them a lot with no issues...
Also it could be a coil that when gets hot could causes issues as well... Ohm test the coil hot and cold It's all in the service manual... Good luck 👍
Disapears if applying just a bit of choke.
Must come around and adjust the carb!
the Tune of the carb is Incorrect...
Received 4,317 Likes
If you need to change your CPS then do yourself a favor and get a Dynatek 2ki and use that instead of the stock stuff.
