Noticed something odd about the drive belt.
I was doing a general inspection and noticed that part of the outside ribs on the drive belt is missing. What could have caused that? Is the missing ribs on the belt something to be concerned about?
smitty901 (07-11-2019)
Do you have the belt guards installed?
Do you ride on gravel roads?
It almost looks like a rock got stuck on upper part of belt as it enters front pulley and caused a strong scrub against back of belt.
A belt replacement is in order.
Unfortunately it is labor intensive as inner and outer primary will need to be removed.
I agree, that looks bad, as it has worn down to the fabric inside the rubber. Definitely in need of replacement pretty soon. I can't imagine how it could happen, so do check running clearances pdq. Might be wise to find a chum to watch and listen, while you wheel the bike while seated on it.
Received 7,672 Likes
